Author: Subject: FWD engine/box and chain drive
Simon
posted on 14/9/18 at 06:07 PM Reply With Quote
Ok, so I was thinking of power unit for a rev trike - something like the 1.0 ecoboost but keep its gearbox.
Does "locking" one driveshaft output and fixing a chain and sprocket to the other (obvs it will need assistance to hold sprocket in place) sound feasable ?
big_wasa
posted on 14/9/18 at 06:13 PM Reply With Quote
Surley the planet gears in the diff won’t with stand that. Ones I’ve looked at don’t run in bearings.
posted on 14/9/18 at 07:09 PM Reply With Quote
Agreed. I wouldn't expect he diff to last long and it would likely be absorbing a fair bit of power whilst it was working.
You could lock the diff completely and run a chain final drive close to 1:1 I suppose.
[Edited on 14/9/18 by MikeRJ]
Daf
posted on 14/9/18 at 07:16 PM Reply With Quote
Not sure of the practicalities on a fwd diff - but could you not weld up the diff?
posted on 17/9/18 at 08:25 AM Reply With Quote
I've not designed or built a trike myself so a quick question...
Do you intend your trike to be mid engine RWD?
If so is it not easier to use a motorbike engine that's surely already designed for this type of setup?
Another question, does a trike have to have a reverse gear?
