Swiftyds
posted on 14/6/20 at 12:44 PM |
Reverse trike - bolt on motorbike frame
Hi
Anyone know if it’s still possible to register a reverse trike on the V5 (modified) for the bike frame if you design the trike frame such that the
entire bike frame/swingarm/wheel and engine are removable such that the bike can be converted back?
I know this used to be allowed by Vosa/DVLA and was similar in process to how you do V5 changes for a rebodied car but the last post I can find about
a similar topic was back in 2013 and I know a lot has changed since then.
I don’t have an issue going for MSVA if that’s now required but would be good to know if anyone has tried to do the bolt on frame (I understand you
have to design the frame such that the headstock is bolted from the bike frame and there is no welding between the trike frame and bike frame)
approach and successfully registered their bike using the V5 as a reverse trike on original reg.
Many thanks
designer
posted on 14/6/20 at 03:58 PM |
Been done for years, and still being done: https://www.2rike.com
SJ
posted on 14/6/20 at 04:49 PM |
Looks like a great idea!
Swiftyds
posted on 14/6/20 at 06:04 PM |
Thanks - already spoke to one of the designers of 2rike but they are telling me they went though MSVA with the prototype?
Are you aware of any other similar builds that have recently been registered without MSVA?
Mr Whippy
posted on 14/6/20 at 08:42 PM |
I think there's two factors here -
1) Can you insure the machine? yes you can, send them a picture explain what it is and get it covered just perfectly
2) Will the DVLA be a pain in the backside if you ask them, probably...
The question is does the DVLA's point of view matter? Personally I could not care less what they think but I'm sure others will tell me
how immorally wrong I'm being, so I say
