scoobyis2cool
posted on 22/8/05 at 04:38 PM |
Dismantling Bosch alternator
Does anyone have any tips for getting a Bosch pinto alternator apart? There's a big nut on the front but I'm having trouble holding the
fan etc still so I can take the nut off. I tried wedging a screwdriver in to stop it spinning but only managed to bend one of the fan fins and take a
chunk out of my thumb Perhaps I could dismantle the main body and hold the main rotor still?
Pete
posted on 22/8/05 at 04:50 PM |
never done it, but my 3 priorities would be some penentrating oil into the thread, attach it to the engine and try to use the fan belt to hold it
still, and then use an impact wrench to suprise it off.
If i was doing it, i would give myself a 0/10 chance of doing it without an air wrench, though you might be more handy!
scoobyis2cool
posted on 22/8/05 at 05:02 PM |
Cheers Joel, I'm not convinced the belt would hold it in place though, it's well and truly stuck on and I think it would just slide
against the belt. Good idea about the penetrating oil though, will give that a go to see if I can at least loosen it up a bit. Once my thumb is
repaired I might be able to get a better grip on the fan, we'll see!
Pete
theconrodkid
posted on 22/8/05 at 05:06 PM |
windy gun is the only way really
who cares who wins
pass the pork pies
scoobyis2cool
posted on 22/8/05 at 05:07 PM |
Even if I had air powered tools I'd need to hold the fan to stop it rotating, that's my main problem at the moment...
Pete
posted on 22/8/05 at 05:11 PM |
Put a socket in your vice (upside down) and sit the alternator nut in it. Then use two big screwdrivers or similar jammed in the fan blades at 180
degrees to each other as levers to turn the fan/shaft.
Oh and a good dose of penetrating oil as well.
HTH
Nick
posted on 22/8/05 at 05:13 PM |
You don't normally need to hold the pulley when using an air wrench, it's the shock that loosens the nut , Take the alternator to your
local garage if you don't have one . P.S. it's probably cheaper to get a recon unit than to repair your own
scoobyis2cool
posted on 22/8/05 at 05:16 PM |
Thanks Nick, unfortunately I don't have a vice, I tend to 'clamp' stuff by sitting on it Also I tried to use a screwdriver before
and it just bent the fin, so I don't think the fins are tough enough to hold still really
Rusty, I don't actually need to repair the unit, it works fine. My problem is that the alternator is slightly offset from the line of the belt,
so that it avoids a chassis rail. This is causing a squeeking noise, so I was hoping to use a washer as a spacer to pack out the belt pulley and bring
it in line with the belt.
Pete
[Edited on 22/8/05 by scoobyis2cool]
posted on 22/8/05 at 05:24 PM |
Probably better to take it to your local garage , would hate to see another injury to you or the alternator . Don't suppose you have a mate with
one of those electric impact guns , not sure if that would work but I'm told that they are effective
posted on 22/8/05 at 05:45 PM |
as rusty says, its suprising how easy it is to loosen things even if they are free to spin. I used it to take the pulley off a power steering pump
that was freely spinning, came off no problem.
However, if you dont have one and cant borrow one, its a moot point anyway!
big_wasa
posted on 22/8/05 at 06:32 PM |
Yep impact wrench is an amazing tool..
Some one near you must have one...
scoobyis2cool
posted on 23/8/05 at 09:04 AM |
Sounds like an impact wrench is what I need then... I'll ask around and see if I can get hold of one.
Pete
Bass1st
posted on 26/4/10 at 07:29 PM |
Did you have any luck?? I have the same problem as I have a replacement Lucas alternator with a V pulley on the front I don't need. Can't
shift it using a manual method!!
Sprytny
posted on 29/4/10 at 08:38 PM |
Impact wrench
Are the impact wrenches that run off batteries any good. I saw an article in the Car Mechanics that debated this, but I am still unconvinced and think
that compressed air is much better.
Any thoughts/ experiences?
iank
posted on 29/4/10 at 08:59 PM |
Scootz got a Makita one and I'm sure he'll be along to say if it's any good. But if you have the space an Aldi compressor and air
impact wrench will be a similar price. Wouldn't bother with a cheap low torque one.
Previous discussion.
http://www.locostbuilders.co.uk/viewthread.php?tid=106321
[Edited on 29/4/10 by iank]
Anonymous
