Author: Subject: Sierra steering column bolts
RoadkillUK
posted on 20/2/03 at 06:59 PM Reply With Quote
Anyone know what size bolts I'll need this weekend to fasten my Sierra steering column to it's new fixings?
It's the ones for the holes arrowed that I need, thanks.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
theconrodkid
posted on 20/2/03 at 07:58 PM Reply With Quote
8mm with huge washers
who cares who wins
pass the pork pies
posted on 21/2/03 at 08:58 AM Reply With Quote
I'm sure it's 10 or 12mm (I'll look tonight).
Conrod's right about the washers - they're about 25 - 30mm dia and about 3 or 4 mm thick.
Note that whatever the bolt size is, it's a fair bit smaller than the hole. I believe the idea is to do it up tight (hence the thick washers). In the event of a bad smash the steering column can slip in the over-size holes and start the collapsing process.
rgds,
dodgyroger
posted on 21/2/03 at 03:23 PM Reply With Quote
Fortunately I retained the original bolts and they are M10 (smug grin). You also need to retain the bushes though which I didn't (not so smug). However you can use the spacers from the seat belt anchors which are the right OD and ID (but a tad long) so they need cutting back about 5 mm then it all fits. Fortunately I retained these (smug again).
You'll also need new M10 nuts and four large washers of cause.
I can provide a pic if need be.
Roger
http://www.dodgyroger.com/locost
