New Topic New Reply
Author: Subject: A slightly odd request
DorsetStrider
posted on 10/10/06 at 12:06 AM Reply With Quote
Hiya all,
I realise this is a slightly odd request and I also realise that this might not be the right place for it... but it seemed as good as any.
If any of you have a 10 inch.... or even 1 inch (and I'll do the math) length of rhs mild steel tubing could you wiegh it for me and let me know what it weighs.
Thanks in advance.
kb58
posted on 10/10/06 at 01:19 AM Reply With Quote
You didn't provide enough information to get a useful answer. Is this material hollow? If so, how thick are the walls?
You know you can find what it weighs using Google...
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
whittlebeast
posted on 10/10/06 at 01:31 AM Reply With Quote
steel is .2833 lbs/in^3 so a 1x1x.063 wall is 12*4*.063*.2833 lbs/ft
DorsetStrider
posted on 10/10/06 at 02:35 AM Reply With Quote
RHS = Rectangular Hollow Section.
but you are right I should have said the sizes and wall thickness.
25mm x 25mm x 1.5mm
Who the f**K tightened this up!
locostv8
posted on 10/10/06 at 03:33 AM Reply With Quote
BUBBA
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
Humbug
posted on 10/10/06 at 06:57 AM Reply With Quote
...except that presumably it's the outside dimensions that are 1", so only 2 sides will be 1" - the other 2 will each be 1" - (2x the thickness)?
If the rest of the formula is correct, then it will be 12*(2+2*0.874)*.063*.2833 lbs/ft
iank
posted on 10/10/06 at 10:39 AM Reply With Quote
Metal Supermarkets have 1"x1"x0.065" which they suggest is 0.827 lb/ft
New Topic New Reply
