the moa 2
posted on 16/11/06 at 11:49 PM |
ZX12-R Vehicle down sensor
I want to eliminate the possibility of my vehicle down sensor stopping the engine while driving .
i have read somewhere that i should fill it with araldite in the up position to prevent it spinning round and making the switch so i opened it up
tonight and thought that surely an easier solution would be to just remove the circle thingey that makes the switch.
Is there any reason why i cant do this ?
oddsaabs
posted on 17/11/06 at 12:27 AM |
I've been dealing with the same dilemma with the zx14 motor I'm readying for install. If I interpret the wiring schematic correctly, we
should be able to just remove the sensor and tie the 3 wires leading to it together. This should keep the circuit closed, thereby keeping the
ignition circuit compete and telling the ecu the bike is upright.
Any comments from those more experienced in such matters?
G.Man
posted on 17/11/06 at 07:23 AM |
Pretty sure thats what I did
Opinions are like backsides..
marc laptop
posted on 17/11/06 at 07:30 AM |
yep i have done this way too
wheezy
posted on 17/11/06 at 08:29 AM |
By far the simplest way is to glue the weight in the correct position. I looked at other ways of by-passing it but I believe it uses a whetestone
bridge circuit so it is not just a case of joining the wires together to fool the ecu.
Dave
the moa 2
posted on 17/11/06 at 10:16 AM |
I wasnt planning on joining the wires but instead just removing the moving part that spins and makes the circiut.
marc n
posted on 17/11/06 at 11:56 AM |
i just reoved the pendulam
marc
please email rather than u2u
chrismnrltd@btinternet.com
G.Man
posted on 17/11/06 at 12:49 PM |
checked mine and the pendulum was removed... works fine
posted on 17/11/06 at 05:15 PM |
We left ours in and fully functional - no problems.
carlgeldard
posted on 17/11/06 at 07:04 PM |
Thats good to here Steve as I was going to leave mine.
Carl
the moa 2
posted on 17/11/06 at 08:26 PM |
I am gonna remove mine tonight as it also makes it easier for me to mount not having to worry about where to mount it.
