Author: Subject: ZX9 exausts
Ben 4x4 Shepperd
posted on 28/8/03 at 11:53 PM Reply With Quote
ZX9 exausts
Guys whats the versict on exausts am I right that the stuart t one is £300 is there any other manufacturers?
I do have the manifold and down pipes could they be used in an exchange?
Need cheap one as I am going to have to start saving for first cars soon!!
Thanks for any help
Ben
MK9R
posted on 29/8/03 at 06:27 AM Reply With Quote
Hi ben,
We bought the Tiger one (£265) without the can. It looks great now but needed a huge amounrt of work to get it to fit the MK correctly (i assume you have bought the standard MK mounting cradle). Have a look at the June page on my site for more details.
I'm not sure if or how the ST would fit, the top chassis rail does sit higher on the MK than the ST in realationship with the engine, which is a good thing, but i'm not sure which direction the crossmember tube goes. To help with clearance and exit angle an easy solution is to put some spacers under the mounting cradle as required. All i can really say is, its a bleedin' nightmare if it doesn't fit first time and good luck!!!
[Edited on 29/8/03 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
