i'm having trouble making the brackets as mentioned in the title.
first off, its the only thing in the haynes book that doesn't say what thickness of plate they should be made of, so working on the side of
caution, i have gone for 3mm flat bar.
i have one of those vice inserts that turns your vice into a press brake but dont seem to be able to get it to fold the steel at perfect right angles
to the length of the bar and also the bar seems to fracture at the back of the bend which isn't a big problem as i have been welding the splits
up and they are strong enough.
does anyone have a foolproof method for this, apart from getting an engineering firm to make them up for me?
i have to say, i'm starting to get a bit envious of all those of you who have bought a completed chassis
i think a lot of people start with 50x50x3mm square tube and chop it into bracket sized pieces.
check ebay out the brakets are for sale on there. Last thing you need is a bracket failing due to stress fractures. try heating the metal prior to bending it
A lot of people use box section with a side sliced off. Drill the hole before slicing the side off though.
P.S Slice off the welded side
Rich
[Edited on 15/3/10 by RichardK]
btw, has anyone noticed that the price of steel has shot up through the roof?
As said, you can buy a bag of them on ebay. Will sort out all your problems and by the sounds of things, quite a bit of time.
You aren't using the stuff that B&Q laughingly refer to as steel are you?
christ no! i know i said that steel prices are high, but B&Q take it to a whole new level! if i were to be using them as a supplier my chassis would have cost about 1K so far
[Edited on 15/3/10 by MikeRJ]
Originally posted by UncleFista
These 'em ?
i can always get some lazer cut for you if there are a few of them
Joe
Haynes roadster brackets (both sizes) are also available from 3GEComponents. Individually or in full car packs (both sizes).
http://www.3gecomponents.com/templates1/view_department.php?department=116&site=63
[Edited on 16/3/10 by iank]
Bright drawn mild steel strip is more prone to stress cracking when folded than black steel.
I also think cutting from RHS is a better method, as others have said.
