Reverse gear sprocket
Sadsy - 17/11/14 at 09:33 PM
Hello Im hoping someone can help me, I have an AB performance reverse kit (few years old) but the toothed gear which sits between the diff and prop is too small in diameter. The starter gear which engages the large tooth gear fouls on the prop bolts which isn't good. I can space out the starter motor to miss the prop bolts but it won't engage the larger gear. I need a larger gear 10mm larger in diameter, 5mm more from the tooth if that makes sense. I have measurements jotted down and have emailed AB but he's a busy chap no reply as yet.
Fisher fury btw
Il add pics asap
Sadsy - 17/11/14 at 10:35 PM
http://i136.photobucket.com/albums/q172/sadsy/Mobile%20Uploads/9902628B-0EE2-4F79-A20D-4C91CDD025B8.jpg
[Edited on 17/11/14 by Sadsy]
Sadsy - 17/11/14 at 10:37 PM
http://s136.photobucket.com/user/sadsy/media/Mobile%20Uploads/2014-11/700FE4CD-1882-4F36-A70A-3008B8D4C841.jpg.html
CosKev3 - 18/11/14 at 07:32 AM
http://www.hpcgears.com/
IIRC the gear on my kit came from above, I bought the kit off here used.
jeffw - 18/11/14 at 07:44 AM
I suggest you speak to Andy at AB...
Sadsy - 18/11/14 at 08:30 AM
Cheers guys, I'm trying to contact ab too No reply as yet
Andy B - 18/11/14 at 08:38 AM
Hi
we have had a few email issues mainly due to a BT interconnect problem (apparently) and I definitely haven't seen your email - we have a number of different sprockets on shelf - give me a call on 01449 736633
regards
Sadsy - 18/11/14 at 07:42 PM
Cheers Andy I know your busy with all the other things! I sent it through your website so it may be that issue. I will ring tomorrow and have a quick chat with you. Cheers
Sadsy - 20/11/14 at 08:09 PM
All sorted..... Andy Bates "AB Performance"has sorted me out with a 150mm gear from stock, this will fix my issue.... Top service, very quick to fix the problem and very helpful on the phone, top man
[Edited on 20/11/14 by Sadsy]
Sadsy - 22/11/14 at 05:02 PM
I received the 150mm gear today, fits perfectly I hope anyone with this issue can use this thread. Thanks AB performance
