I assume the panther uses the std sierra items?
If not what does it use?
The handbrake will be a shorter version of the original.
On Darrens demo car he has a sierra handbrake cable cut in half, wound around the half moon bracket and then clipped together. A few people have done
it this way although I did hear about someone failing an SVA on this. I believe it is safer to thread the 2 ends through a balance bar and terminate
with solderless nipples (Available from CBS)
The clutch cable I am using is from an old Cortina. The sierra one is a little too long :-(
Sierra handbrake is fine but the Sierra clutch is too long. The Cortina clutch is better.
Are you using drums or discs on the back David?
Thanks for the input so far guys
Looks like sierra handbrake, and cortina clutch then.
Drums up the back Brian.
