I have a new fuel gauge which I hope will match up with the recently obtained sender. Both are rated at 270 ohms/ 18 ohms. The wiring connections are
shown below.
Fuel_Gauge_Wiring
I plan to test gauge and sender off the vehicle, using this wiring set up. Should I also connect a resistance load in parallel with gauge and sender,
to prevent possible excessive current loading?
I welcome your constructive advice.
In my opinion no, there will be no current between sender and gauge, only a resistance value between sender and earth.
some gauges run off 9 volts via a stabaliser, just to prevent the gauge going up n down with battery voltage, should be written on the units or in the
paperwork if you have any, worth a punt round on-line.
quote:the old style gauges ran on a nominal 9 or 10V system. but that was a by-metallic strip, switch open and closed. (quite slowly, but a early form of 'pulse width modulation' for voltage control.)
Originally posted by theconrodkid
some gauges run off 9 volts via a stabaliser, just to prevent the gauge going up n down with battery voltage, should be written on the units or in the paperwork if you have any, worth a punt round on-line.![]()
You should wire it up as per the diagram.
I would recommend a modern 9V (7809) or 10V regulator in the circuit
actually for testing, just use a pp3 9v battery
ok, try it on a car battery
