Morning,
Could anyone advise on how the fuel filler system is constructed?
On my tank I have a large diameter open hole where I presume the main filler hose connects. Right next to this I have a smaller diameter sealed
pipe.
I can buy all the parts from Dax for £116 + VAT + delivery. Does this seem reasonable? Can anyone give me a complete parts list?
[Edited on 25/3/10 by cd.thomson]
i would assume the small one is a breather, but do you need a return from your engine setup??
where are you mounting your fillercap???
top or on the back pannell??
large diameter open hole??
does it have holes on a pcd??
this could be the sender hole??
the inlet will have a tube...
Pics? As above, you're probably looking at the sender hole. If dax are offering filler neck, cap and sender for that price it's pretty good, if there isn't a sender with it I think thats a bit steep.
all i know is you're using carbs,m so you don't need a fuel return thingy
sorry I don't think I've made myself clear. The fuel system from tank to carbs is fully finished.
I'm trying to figure out how to actually fill the tank up from a petrol pump rather than just sticking the hose into the large pipe in the top of
the tank
I understand I need filler hose, breather hose, vents, filler caps, restrictors and all sorts, but I'm not sure what I need to buy..
eta- boggle, I'm mounting it on the rear end, horizontally. i.e. at right angles to the large diameter pipe.
eta- tom prices are listed as follows:
Filler cap ~ flush fitting lockable £ 75.95
Filler Pipe Assembly. £ 40.20
Which I presume is everything I need.
by "sender" do you mean fuel level sender? this is fitted already too.
Yeah I meant fuel level sender so if that's finished then all you need is the filler. The pumps automatically stop when pressure reaches a certain point - as far as I know if you have a breather and all of your lines sorted it should just be a case of filler neck and cap. I think that both of those are a bit too expensive to be honest, I would be lloking at £50 and under for the filler cap, and circa £30 for the neck.
seems like a lot of money for the filler cap. shop around!
filler cap and funnel can be had for a lot less surely? then you just need a bit of fuel filler hose
Okay, so I dont require a breather, non-return valve or unleaded insert? Say I filled the tank and drove the car for a few miles wouldnt a dodgy
vacuum be formed?
fuel filler cap from cbs is £71
filler neck £20
2" fuel filler hose £18
all before VAT and delivery so perhaps the Dax values are right..
Hi
On Mine the filler neck has a small vent take off at the top which needs routing via a small diameter pipe at high level to the opposite side of the
car ( off side in my case ) to end up at low level below the tank.
Does that help
