iv got some coolent leaking from the water pump area(zx10r),do you know if you can get the o ring on they own or do you have too buy a water pump,anybody any ideas where too buy the seals or water pump,thanks
If it's a simple O ring and you can measure the diameter and the section you'll be able to buy one from any industrial bearing type outlet.
You'll find all the sizes on the web. I'll have a look for you.
ETA Have a look here.
[Edited on 7/1/11 by MikeCapon]
i dont know what size they are,iv not removed the pump yet,thanks for that info.
Hi most bike pumps have a blow hole in them if water is leaking from there then its usually a replacement pump but you may get a seal gis a ring
i may have a pump in stock iv broke a few zx10,s
cheers Malc 07960011585
[Edited on 8/1/11 by yorkshire-engines]
