<<  1    2    3    4    5    6  >>
Author: Subject: Gulf MNR Vortx
Digimon
posted on 21/6/13 at 05:45 PM Reply With Quote
Well the new engine is in and running, its been quite a learning curve we had the engine in a out quite a few times because I couldn't get the chassis engine mount bolts to start but the 3rd time the engine was taken out my dad noticed the mounts on the gearbox case are not taped from the factory, the bike must use really long bolts doh
Hopefully someone will be able to answer this one, R1 owners out there is it normal for these engines to breathe heavily at the moment ive only got a little K&N filter on the breather and im getting fumed out and small amount of oil is getting past the filter. I'm hopefully doing a trackday at the end of the month and I'm thinking it needs a proper catch tank and a return to the carbs/air filter to draw the fumes away, what have other people done to get around this problem?
The only other problem i've got is the clutch is slipping at high rpm but i'm going to fit the clutch from the old engine as that was ok, i've not tried yet but can i get the clutch cover off with out removing the engine cradle ???
got two new gaskets for the baffled sump
engine in all plumbed and running
Finally fitted the quick shifter but I've not set it up yet
gaz_gaz
posted on 21/6/13 at 06:07 PM Reply With Quote
I can get the clutch cover off my mnr without removing the cradle
Also if you jack the car up to the third hole of a plain axel stand you wont need to drain the oil.
Something to consider I have fitted two clutch diaphragm springs, this has improved clutch feel (made it heavier) and should improve clamping force.
[Edited on 21/6/13 by gaz_gaz]
johnny chimpo
posted on 21/6/13 at 06:51 PM Reply With Quote
I've got a 5pw r1 engine in my MNR and after its winter layup there was a lot of smoke/fumes coming from the breather the first few times it was started up. I done a bit of googling and this seems to be normal if its been sitting for a while, so could be the same reasons for yourself.
It might be worth investing in a catch tank if you've not got one that way you can monitor how heavily it is breathing.
Well done on getting your car sorted so quick. I'm pretty sure if my engine pops the car will be off the road till the following year at the earliest.
[Edited on 21/6/13 by johnny chimpo]
Digimon
posted on 21/6/13 at 06:59 PM Reply With Quote
Thanks for the tip Gaz ill definitely do that when I swap the clutch out
Digimon
posted on 21/6/13 at 07:03 PM Reply With Quote
Hopefully mine will be the same as your car johnny and it will clear up in time
Agriv8
posted on 21/6/13 at 07:12 PM Reply With Quote
Another thing to check with clutch is that the cable outter is seated correctly still one of my fave MNR's
ATB Agriv8
Digimon
posted on 23/6/13 at 02:41 PM Reply With Quote
Got the clutch sorted today, swapped them over and fitted two diaphragm springs.
wow what a difference, thanks for the tip Gaz
gaz_gaz
posted on 23/6/13 at 08:30 PM Reply With Quote
Glad to help.
Just noticed your comment on the breather, I get a bit of vapour from mine, used to have the same filter as you but I've just fitted a cheapy oil catch tank (£20 from ebay)
The new engine you've bought wasn't the freshly rebuild item that was for sale was it?
[Edited on 23/6/13 by gaz_gaz]
Digimon
posted on 24/6/13 at 08:00 AM Reply With Quote
No I got the engine from eBay, it had 29k on the clock
[Edited on 24/6/13 by Digimon]
Digimon
posted on 26/6/13 at 07:51 PM Reply With Quote
Installed an oil catch tank tonight thanks to hopsky1 for the tank
I'm really happy with how it’s turned, the return to the carb’s has a taper so it's done up nice and tight but I’ve put the split pin through it just in case it decided to fallout at some point
hopsky1
posted on 26/6/13 at 08:57 PM Reply With Quote
looking good si.ive got fuel pump probs with minegot a new one orderd hopfully be here friday nothing like last minute .com lol
Digimon
posted on 27/6/13 at 07:05 AM Reply With Quote
Thats not good mate, hopefully you get it all sorted in time
Ben_Copeland
posted on 27/6/13 at 11:23 AM Reply With Quote
Time to get out and play!
Would come visit but my head gasket went yesterday returning from work so I've got to change cylinder heads too
Ben
Locost Map on Google Maps
Enter Your Details Here
Digimon
posted on 28/6/13 at 05:49 PM Reply With Quote
That's crap mate, hope you get it sorted soon
Digimon
posted on 2/7/13 at 07:43 PM Reply With Quote
My first track day was a success the car didn't blow up and I managed to keep it out of the gravel traps
One of my dads mk1 escort
[Edited on 2/7/13 by Digimon]
perksy
posted on 2/7/13 at 09:38 PM Reply With Quote
Pleased you had a good day and everything went ok
Any chance we could have a few more photos of your Dads Mk1 please as it looks very nice indeed
Digimon
posted on 3/7/13 at 07:11 PM Reply With Quote
Here's a few more photos of the Mk1 and spec
ST170 engine
Ported Head, Matched Intel Manifold
VVT Delete CatCams + Cat Pulleys
Jenvey Throttle Bodys
Omex 600 management
ARP Conrod bolts
ARP Flywheel bolts
TTV Racing flywheel
Race Line bits and bobs
4 speed Tran-x straight cut gearbox
Tran-x LSD
Quick Rack
GRP4 front struts
GRP4 Alloy Hubs with larger wheel bearing
Rally Design tension kit
Gaz Gold Rear Shocks
Decambered leaf springs
AP Racing 4 pot Calipers
Sierra Cosworth Rear Calipers
[Edited on 3/7/13 by Digimon]
perksy
posted on 3/7/13 at 07:32 PM Reply With Quote
Thanks for that
Always good to see a nice Mk1 and that looks lovely
Nice to see it being used in anger aswell instead of being wrapped up in the garage
Ben_Copeland
posted on 3/7/13 at 08:36 PM Reply With Quote
Should be back together Saturday morning
Ben
Digimon
posted on 11/9/13 at 09:18 AM Reply With Quote
I had a interesting day at Lydden Hill on Saturday, one my bonnet clips came undone on the 2nd lap pulled of and a nice marshal put it back down for me. Went back out and did 10 or so laps later and this happened down the start / finish strait
Strangely tho because I wasn't the only MNR Vortx and the other one had the same problem but lucky he's bonnet didn't come off.
Lots of gaff tape later......
Lucky the bonnet didn't hit any other car's but it did rip the air filter off and smashed wing mirror
I have emailed MNR about a replacement bonnet so hopefully its not to expensive
johnny chimpo
posted on 11/9/13 at 09:40 AM Reply With Quote
Unlucky, bit of a weird one that both MNRs had similar problems.
I think last time i enquired about a new bonnet, it was about £135 ish.
Ben_Copeland
posted on 11/9/13 at 10:25 AM Reply With Quote
Nearly lost my bonnet on the motorway when I forgot to clip it down properly.
Luckily it caught of the exhaust manifold, I slowed down and it popped back down again.
Hopefully the weather will improve a little and we can go for a blast together.
Ben
Digimon
posted on 11/9/13 at 03:29 PM Reply With Quote
That's not to bad, hopefully it will be about the same price
Yeah that sounds good, hopefully the car will be sorted soon
Dan.
posted on 24/12/13 at 12:27 AM Reply With Quote
Hi Si,
Long time no see, I'll have to come have a look at the car when I'm down, looks a great bit of kit Must get mine finished!
Digimon
posted on 2/1/14 at 01:39 PM Reply With Quote
Originally posted by Dan.
Hi Si,
Hey Dan,
Yeah it has been to long, let us know when your coming down and were have to go out for a drive. Or tho you might what BEC after lol
<<  1    2    3    4    5    6  >>
