omega0684
posted on 13/3/09 at 02:47 PM |
boot cover fixing
my boot cover studs keep coming off! the boot cover is attached by press studs and i have superglued the bases to the rear tub but they keep
coming off! can anyone suggest a way of fastening the base studs to the tub so they don't come off!
[Edited on 13/3/09 by omega0684]
splitrivet
posted on 13/3/09 at 02:50 PM |
Pop rivets are what I used.
Bob
James
posted on 13/3/09 at 02:52 PM |
I thought most used rivets too. Watch out for doing them too tight if you've got a GRP rear.
- Muhammad Ali
bob
posted on 13/3/09 at 02:54 PM |
Mine are bolted on with very small stainless countersunk bolts.
omega0684
posted on 13/3/09 at 03:01 PM |
i tried pop rivets but then the press stud doesn't clip in
Mr Whippy
posted on 13/3/09 at 03:05 PM |
i'd have used these rather than the poppers
linky
Paul TigerB6
posted on 13/3/09 at 03:08 PM |
Rivets for me too. I needed to cut a small disc of steel with a hole drilled in it to enable me to pull the rivets inside the press-stud with my rivet
gun.
Hammerhead
posted on 13/3/09 at 03:19 PM |
how about stainless self tapping screw?
Davey D
posted on 13/3/09 at 03:38 PM |
instead of superglue try using PU adhesive like Tigerseal. That stuff will stick anything together
Jubal
posted on 13/3/09 at 04:03 PM |
I had a similar problem on my old car and used countersunk self tappers into a flat nut behind the GRP. Worked a treat.
sucksqueezebangblow
posted on 13/3/09 at 04:47 PM |
Use backing washers to stop the rivets pulling through the fibreglass.
