Author: Subject: Velocity questions
Rubin
posted on 14/4/09 at 10:28 AM Reply With Quote
Velocity questions
Unfortunately had an off and have damaged my velocity.
I need some new bodywork so looked back thru my Luego info for the RAL colour but all I have is that it is "Luego Orange" - anyone know the RAL code ? pic attached if that helps
Also need a rear camber adjuster - can I only get these from Luego or are they off the shelf anywhere ?
bill132hotrod
posted on 14/4/09 at 10:58 AM Reply With Quote
velocity parts and Ral Codes
Go to Luego website the have a colour chart and also i think its only Luego that make the offset mushroom top hat.
Good Luck.
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
Rubin
posted on 14/4/09 at 11:20 AM Reply With Quote
thanks, couldn't see the colour selector at first but found an old link - it's RAL 2003
On the camber adjuster it's the rear one i'm after not mushroom on front - i'll give luego a call later today
thanks again
Sebastian
posted on 14/4/09 at 11:56 AM Reply With Quote
If you are going to order new bodywork i would ask about the colours they are using now, because i heard that he has switched suppliers.
Unless you got the current bodywork also from Ben.
