bi22le
posted on 13/8/09 at 10:32 PM |
Where shall i put my camera?
Im doing a track day soon and want to get a camera mounted. As you can see There is not a clear view due to the large rear view mirroe. I would like
to see the speedo so I can work out fast and slow points for next time!
here are some pics, hope they work!
Please read my ring story:
posted on 13/8/09 at 10:42 PM |
Ooo, do you want to mount your camera or hide it way some where dark?
Got any hamsters you want to photo? if thats the case you know where top put it...
paul the 6th
posted on 14/8/09 at 12:37 AM |
Helmet cam
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
Macbeast
posted on 14/8/09 at 05:30 AM |
Can't see the pictures - only box with red cross. This happens occasionally but never found out why ![](/images//smilies/sad.gif)
blakep82
posted on 14/8/09 at 06:07 AM |
![](/galpreviews/SDC12992 resize resized.jpg) ![Description](/gallery/SDC12992 resize resized.jpg) Description
in the middle, on the diagonal of the rear hoop,
![](/galpreviews/SDC12974 resize resized.jpg) ![Description](/gallery/SDC12974 resize resized.jpg) Description
________________________
sorens2
posted on 14/8/09 at 07:38 AM |
Turn it to a rearwiev.
Gives a good effect if thereare ups and downs.
http://www.youtube.com/watch?v=7MXzQfkmTD8
This is my favorit.
You can se steeringmovement, gear, wheel and road.
Soren S2
procomp
Hi
The most obvious place is on the Diagonal in the main roll hoop. With it offset to the left it will give good view of the track and gauges will be
clearly viewable. It will also make mounting in an acceptable manner easy as theres quite a few camera mount that will attach to roll bars very
easily.
Cheers Matt
myke pocock
posted on 14/8/09 at 08:14 AM |
Hells bells!!! Thats some rear view mirror youve got there.
franky
posted on 14/8/09 at 08:15 AM |
if you're really after seeing the dash you'd struggle to see that and the track.....
franky
sucksqueezebangblow
posted on 14/8/09 at 01:24 PM |
Fit it with a roll-cage mount to the left or right of the rear view mirror.
Jubal
posted on 14/8/09 at 02:25 PM |
What he says. I'd go for getting the best view of the track and the front of the car so you can see your lines. You'll easy spot where you
are fast/slow without needing the speedo in shot. This is from my old car, cam mounted on rear roll bar.
http://www.youtube.com/watch?v=nL0gYxNVLi8
The dash is visible but speedo could only be read in the original footage, just. A narrower angle cam might help.
bi22le
posted on 14/8/09 at 06:58 PM |
Its evolved now. I have the chance to use two cameras. That way I could have a front \ back situation. Or a speed \ good driving positon set up. I
dont think a helmet cam would work. It would just look at ther rear view or cross bar at the front! I like the large rear view mirror. I have no blind
spots and can easily see what going on around me. I know I could turn my head but that does not help with a bash hat on.
Thanks for posting up my photos! What did i do wrong?
blakep82
posted on 14/8/09 at 09:57 PM |
you took the url of the page the photo was showing on, not the actual photo.
where did you get the mirror from? quite fancy one like that myself
franky
posted on 14/8/09 at 10:01 PM |
You're better off having a gps trace or using the data logging function. The problem with trackdays is traffic so you'll struggle to
follow the racing line all the time.
