speedyxjs
posted on 2/10/09 at 09:38 AM |
Water pump locost repair
Iv just been out doing various check before running the engine with a cooling system tomorrow adn all is well except the water pump is leaking.
It is dripping at a rate of 1 drip every 2ish seconds from the radiator inlet.
Looking a bit closer, i can see it being one of two problems.
1) The reduser hose i cut down could be too short although the jubilee clip covers the whole hose with a bit left on either side.
2) The ridge on the rad inlet on the water pump has a little (2cm) piece missing. I wouldnt have thought this would be a problem with the jubilee clip
on though.
Does anyone have any ideas as to how to stop the leak without spending money on a new water pump?
blakep82
posted on 2/10/09 at 09:48 AM |
might be because the hose can't 'shrink' to clamp round the pump, but needs to deform, meaning there might still be a small gap
round it, no matter how much you try to tighten it. the bit missing out the pump won't help either.
if you just want a test run tomorrow, that drip won't hurt.
perhaps consider a hose reducer to get down to the right size?
________________________
speedyxjs
posted on 2/10/09 at 09:55 AM |
Yeah ok. Should i be wirried though that the drip is right next to the alternator?
posted on 2/10/09 at 09:58 AM |
Make sure the alloy pump inlet is clean and free of corrosion. If it's badly pitted from corrosion you can make a pretty good repair to this
kind of damage with epoxy (e.g. JB Weld).
For a quick solution a spot of gasket sealer around the inlet before you refit the hose will likely stop the leaks, but this is a bodge.
I'm assuming the hose is a reasonably tight push fit onto the water pump?
[Edited on 2/10/09 by MikeRJ]
blakep82
posted on 2/10/09 at 10:04 AM |
nope. it will have been exposed to all sorts of wetness (well, rain water mostly) on the jag, and in your car, so a few drips will be fine
i had a fuel leak right above my starter, dripping lovely petrol into the electrics on my old bmw for a good few days before i noticed. and i noticed
without any explosions
deano 777
posted on 2/10/09 at 10:43 AM |
Hi, you could always add an aditive to the cooling system to stop the leak, K-seal is very good. or rad seal. good luck.
speedyxjs
posted on 2/10/09 at 11:04 AM |
Cheers guys. I just went out and made a new ridge with the stuff i used to seal the fuel tank the other week, waited for it to dry and then put some
liquid gasket on.
Seems to have stopped the leak but il wait until tomorrow before i carry on with more water.
posted on 2/10/09 at 12:05 PM |
Bung an egg in the coolant.
Or fix it properly I agree building up the ridge with JB weld would be the best option for the 2nd problem. Can't see an alternative on the
1st but to get some longer hose.
PS- too late!!
[Edited on 2/10/09 by BenB]
speedyxjs
posted on 2/10/09 at 02:33 PM |
Turns out its still leaking
I put the reducer from the top hose on ot to see if it was the hose but its not.
I have now used the stuff i used to fix the tank right round the rose and clamped it on so whe it dries, hopefully, it will seal it and also put
liquid gasket all round the inside of the hose.
