posted on 23/11/09 at 09:40 PM |
Demist?
(I'm not sure if this is the best place to discuss this... but here goes anyway... )
As part of my windscreen project I want to fit some form of demisting system. I know people have said that I won't need one - but I'd
prefer to have it available.
I've looked at those CBS electric fans, and read some of the reviews, and decided that they aren't what I want (they're a bit bulky,
there's not a lot of space, they consume a lot of power - nearly 15A each - and the general opinion is that they don't work very well).
The CBS heater & demist system that's plumbed into the engine's cooling system is just too expensive - it'd be around £200 once
I'd bought all the bits needed.
So - what's the alternative? Passenger heating is not required (I've managed so far) so a Polo heater might be OTT (and probably a bit
bulky).
Has anyone tried to make their own? I was thinking of a small-ish fan, a home-made heat exchanger matrix, a few water pipes and a bit of duct work.
I'm not afraid of the work involved, but it would be nice to know that it has a chance of working if I did make one.
All bright ideas and opinions gratefully received!
morcus
posted on 23/11/09 at 09:45 PM |
I don't really have an answer but I'm intrested, I hope to build a car with a screen and a hood so I can use it in the rain.
I would have thought the pluming it into the engine heating stuff would be easiest and £200 doesn't sound like alot of money for the result.
Personally I'd go with the polo heater option for the luxury of cabin heat.
posted on 23/11/09 at 09:49 PM |
Have a word with your local friendly radiator specialist , they may have a matrix that's suitable .A heater box should be difficult with a
couple of outlet to some demister ventsand a fan should be easy possible an MG Midget ? Reliant Robin heater may be suitable if you can find one?
Did you sort out a water outlet when you made your inlet manifold?
austin man
posted on 23/11/09 at 09:53 PM |
as the previous post buy a small matrix make your own box, you could consider using a pc fan to draw the air through a pipe I have used hoover pipe
previously on my Austin a35 found it to be more manageable than the plastice piping and realy lo cost as I got if from a Knackered dyson
mangogrooveworkshop
posted on 23/11/09 at 10:04 PM |
Macspeedy used a Sierra one and just made a box out of ali for it.
U2u him for the details
lsdweb
posted on 23/11/09 at 10:07 PM |
12volt ceramic heater? You could hide it away behind the dash and make some ducting -
link and it's only a tenner so if it doesn't work you've not lost a lot!
Wyn
Dangle_kt
posted on 23/11/09 at 10:13 PM |
I'd leave it if I was you...crapist heater on the planet, or at least it was in both of mine...![](/images//smilies/sad.gif)
posted on 23/11/09 at 10:19 PM |
That's a thought - there's a good radiator place in Ipswich so I might have a word.
I've still got the original place to plumb in the heater, between the water pump and the inlet manifold - there's just a plain hose
between the two at the moment, so that's easily sorted out.
My current thought is an aluminium box containing the matrix, 'snail' fan bolted on, and air outlets on top. This can be bolted to the
passenger side of the firewall with the water pipes poking through to the engine side - this should reduce the risk of scalding if the hoses fail (as
has happened to a few forum members, including a couple just the other day - very nasty).
As for the electric jobs - the one mentioned is 150W, so that's around 12A current. The average water-powered car heater is 4 or 5 KW, and
that's only using waste engine heat, so there's no comparison (if you ignore the few Amps for the fan).
speedyxjs
posted on 24/11/09 at 07:10 AM |
You have obviously never used (more like tried to use) the heater from an mg midget. You would be better off with a passenger breathing on you!
Humbug
posted on 24/11/09 at 08:27 AM |
Unless you want the heater for heating as well - and I am guessing most of the heat disappears into the sky anyway - what about a heated screen
instead? You can find the odd Caterham one for nto too much money.
I went from aeroscreen to full screen and have fitted a Caterham heated screen. It'w wired up, but I just need to wait for a cold morning to try
out the screen ![](/images//smilies/smile.gif)
posted on 24/11/09 at 08:41 AM |
Nonsense to both of ya, you clearly have neveer driven a Sereis Land Rover.
A baby asthmatic mouse could do a better job.
To make your own, you need a small radiator and fan. For radiator look at oil coolers, either Mocal type or locoster version is motorcycle ones -
loads on ebay.
hughpinder
posted on 24/11/09 at 09:20 AM |
I stripped down the mx5 and mondeo heater boxes. the 'radiator' part in the mx5 is actually only about 8"*6"*1.25", and
the mondeo one is only slightly larger. Quite difficult to get out of the car usually, but only £2 from your local scrappy! I plan to use a couple of
12V PC style fans and some aly duct
Regards
Hugh
posted on 24/11/09 at 02:59 PM |
I'm using an oil cooler. PC fans are rubbish, they hardly flow and cfm.
Centrigual fans are much better as they'll cope better with back-pressure than axial fans.
morcus
posted on 25/11/09 at 12:21 AM |
Just out of intrest, does anyone make a windscreen with all the ancillaries atatched that could be bolter on and plugged in as a unit?
Angel Acevedo
posted on 25/11/09 at 08:11 AM |
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Modyfied Hairdryer???
907
posted on 25/11/09 at 08:32 AM |
I have been wondering if air ducted from around the exhaust would be more efficient.
The exhaust gets hot before the water system does.
Paul G
posted on 25/11/09 at 12:46 PM |
I think that an old-style VW used to do that - Kamffwagen (or some such name).
I'd be concerned about exhaust leaks - but in an open top car that's less of an issue! Apart from that, I'd guess that you'd
have to blow cold air into the heat exchanger, rather than suck hot air out...
Paul G
Mave
posted on 25/11/09 at 04:34 PM |
How about this one then?
Ebay linky
posted on 25/11/09 at 04:42 PM |
That looks ideal - apart from the price!
iank
posted on 25/11/09 at 07:35 PM |
What about a VW polo heater.
Small, cheap and proven.
See this thread
http://www.locostbuilders.co.uk/viewthread.php?tid=21377
and ayoungman's photo archive for pictures of the bare heater.
Anonymous
edspurrier
posted on 26/11/09 at 09:19 PM |
Second heated screen. Wire it in with a timer relay from CBS and bingo.
posted on 26/11/09 at 09:27 PM |
But where would you get a heated screen made to measure?
posted on 2/12/09 at 09:19 PM |
I'm getting fed up with this windscreen project!
Fitting the windscreen is going OK, doing the wipers and screenwash should be fine, and I have no worries about the extra switches and wiring.
However, I had a good look under the scuttle over the weekend - and if I want to fit any sort of fan-driven water-powered heater for demist then
I'm going to have to move a load of wiring, relays and my Megajolt unit. This work would involve a LOT of rewiring.
The CBS electric units are actually quite bulky and will get in the way.
In all honesty, do I really NEED demist (I've done SVA)? Would I be OK with a regular dose of Rain-X Anti-Fog instead?
morcus
posted on 2/12/09 at 10:27 PM |
You could get your self a wiping pad and just wipe it clear when you get in and when it needs it but its dangerous, do you really want to risk your
life?
I was under the impression that if you clear a screen and then leave the windows open it wouldn't mist up again because it would be the same
temp both sides and the water vapour would not be trapped. All said, I'd want a demister of some sort.
Angel Acevedo
posted on 2/12/09 at 11:27 PM |
Hairdryer... Again...
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=12v+hair+dryer&_sacat=See-All-Categories
This one is 360 Watts.
Pricier though.
http://www.1-800-espresso.com/hair-dryer-12v.html
[Edited on 12/2/2009 by Angel Acevedo]
