franky
posted on 20/11/10 at 07:16 PM |
where to get these, or make them cheaper?
http://www.cbsonline.co.uk/toggle-switch-guard-swguard-3583-p.asp
£6+vat for one seems a little like daylight robbery
I've been looking for some oval hoops to cut in half and put a thread on with no luck so far..... locost builders always have the answer!
tegwin
posted on 20/11/10 at 07:24 PM |
Can you find a new (BMW) mini... the centre switch panel has those on it...
www.verticalhorizonsmedia.tv
designer
posted on 20/11/10 at 07:28 PM |
I used an IKEA draw handle to guard my switches.
designer
posted on 20/11/10 at 07:29 PM |
Or, a small U-bolt would do for a single switch.
flibble
posted on 20/11/10 at 07:33 PM |
Might be possible to chop these down then thread the end for a nut or similar?
5mm STAINLESS STEEL 316 Dee Shackles Chandlery on eBay (end time 08-Dec-10 13:54:43 GMT)![](http://rover.ebay.com/roverimp/1/710-53481-19255-0/1?ff3=2&pub=5574934589&toolid=10001&campid=5336738914&customid=&item=123456&mpt=[CACHEBUSTER])
Strontium Dog
posted on 20/11/10 at 07:35 PM |
Just bend a bit of straight bar around a former of your choice. Ally bar would be easy to cut threads on!![](/images//smilies/wink.gif)
Davegtst
posted on 20/11/10 at 08:06 PM |
I've been looking for some cheaper ones for ages. CBS must get them from somewhere.
austin man
posted on 20/11/10 at 08:09 PM |
what about cable clamps
PK10 CABLE CLAMP 6MM on eBay (end time 04-Dec-10 10:23:15 GMT) 3
jacko
posted on 20/11/10 at 08:28 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=145388
This any good for you
[Edited on 20/11/10 by jacko]
Davegtst
posted on 20/11/10 at 08:48 PM |
I've thought about using those mini ones, can you take the guards off and mount them to a flat panel?
[Edited on 20/11/10 by Davegtst]
stevegough
posted on 20/11/10 at 09:11 PM |
You could try these from CBS?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
franky
posted on 20/11/10 at 09:32 PM |
Cheers people, I think these are the best to go for
6mm x 90mm U BOLT & PLATE STAINLESS STEEL 316 on eBay (end time 25-Nov-10 15:22:33 GMT)
They have an edge to go against the panel too with a smaller pitch thread. So 1/3 of the price of the highway robbers![](/images//smilies/bigsmile.gif)
Davegtst
posted on 20/11/10 at 09:35 PM |
Good find. Be sure to let us know what they are like when you get them, i'll probably get some too.
Alan B
posted on 24/11/10 at 02:43 PM |
Agreed 6 quid is pretty expensive there must be something better. However, a couple of points.....for those suggesting threading a pre bent
'U', how can you do that?...think about it.. and secondly the CBS ones do have a small flange forged into them allowing you to tighten
them up without having a nut both sides....which is more visually appealing than the nut showing.....
Just my thoughts.
Alan
Mix
posted on 24/11/10 at 05:49 PM |
Come on Alan - surely die nuts exist that side of the 'pond'
Regards Mick
Davegtst
posted on 24/11/10 at 10:05 PM |
Look what i just found. Wrong side of the ocean though.
http://www.periheliondesign.com/switchguards.htm
franky
posted on 26/11/10 at 05:08 PM |
The ebay ones seemed to work well. £1.70 against £6+vat!!! Not a 100% finished job but i'm pleased with how its turned out.
[Edited on 26/11/10 by franky]
stevegough
posted on 26/11/10 at 05:11 PM |
Missile silos?
Luego Locost C20XE.
franky
posted on 26/11/10 at 06:02 PM |
Hidden rocket launchers
Fuel pump/Fan over-ride/Dash power/traction-launch control
I just like toggle switches, well switches full stop!![](/images//smilies/wink.gif)
