Irony
posted on 23/2/12 at 09:32 AM |
Ruined my battery
Do to my naivety and lack of experience I have I think completely ruined my brand new never been used VARTA battery. I bought it a year ago and have
foolishly left it without charging it. I put the multimeter across it the other day and no voltage whatsoever. Is this battery now completely
ruined? I haven't tried charging it.
I did by it from a local motor factor and having read up on here about it I made sure it's got either a 4 year guarantee or maybe 5 year. Has
anyone tried taking a battery back and in what circumstances is a exchange likely?
[Edited on 23/2/12 by Irony]
Bluemoon
posted on 23/2/12 at 09:35 AM |
Charge it first, see if it recovers (you never know you could be lucky).
owelly
posted on 23/2/12 at 09:42 AM |
Have a looksy at the plates. If they are all wavy and furry, chances are it's knackered in which case return it under warrenty but don't
tell them it's been sat for a year!
http://www.ppcmag.co.uk
wilkingj
posted on 23/2/12 at 09:50 AM |
+1
Best Regards
Geoff
http://www.v8viento.co.uk
roadrunner
posted on 23/2/12 at 10:06 AM |
The thing with these new battery chargers, is that they need to recognise that a battery has been connected to start the charge. If your battery is
completely flat , try fooling the charger by dropping a 12v current across your battery pins. I use a drill/driver battery.
Brad.
P ?
posted on 23/2/12 at 10:19 AM |
i shopped for batteries purely for the 4/5 year guarantee... halfords at one point knew what i wanted before i said anything 7 times in a year swapped
a battery ... the good old days of large stereo's hehe
just need your receipt
posted on 23/2/12 at 11:22 AM |
Frst try this, Put it on a slow charge for 24+hours don't be surprised if it takes 12 hours before it starts to take more than a tiny
current if the battery is taking charge the current will eventually rise then slowly fall off as full charge is approached.
clanger
posted on 23/2/12 at 05:00 PM |
optimate is your friend, flat batteries are a way of life for us bikers ![](/images//smilies/bigsmile.gif)
pewe
posted on 23/2/12 at 05:22 PM |
Back in the bad old days we used to whack 30amps into totally flat batteries on the grounds that they were sweet FA use anyway. Surprisingly 9/10 they
resurrected themselves but you couldn't wander off and leave then cooking!
If all else fails take it to a local friendly garage and ask them to whack some charge in to wake it up.
BTW clanger just back from a sneaky two wheel blat - boy do I miss that!
Cheers, Pewe10 ![](/images//smilies/cool.gif)
clanger
posted on 23/2/12 at 05:30 PM |
Cheers, Pewe10
waiting for the salt to go before pulling the covers off the 748 ![](/images//smilies/smile.gif)
posted on 23/2/12 at 07:24 PM |
There is a difference between a flat battery and an absolutely flat battery with no charge at all.
plentywahalla
posted on 23/2/12 at 08:40 PM |
Agreed ... if it has just gone flat then it won't have caused any damage/buckled plates etc. If you whack a big charge into it now, that is when
the damage is done. Charge it on a very low current, less than 1 amp or so for 24 hours. You have to slowly bring it back into life.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
