jakeob
posted on 10/4/12 at 03:41 PM |
R1 Clutch basket Nut?
I am trying to remove the Clutch basket in my r1
Whats the best way to hold the drum still while i get some pressure on the 32mm nut in the centre
Neil
Pdlewis
posted on 10/4/12 at 04:06 PM |
this is a real pain as im sure you have found
I got one of the metal disks which sit between the clutch plates and put braces across and attached a handle this way the force was spread across all
the notches not damaging any of them
Build Photo Album
Updated 05/02/2009
smart51
posted on 10/4/12 at 05:01 PM |
Be ware of e clutch basket. I snapped bits off mine. Luckilly I had a spare engine for salvaging parts. I think I welded something up in the end.
jimgiblett
posted on 10/4/12 at 05:07 PM |
Use a rattle gun to shock it off. I dont like the braces either as the basket is quite fragile.
- Jim
PAUL FISHER
posted on 10/4/12 at 05:11 PM |
Yes air gun works, but if not have you tried putting it in gear, with the handbrake on.
DIY Si
posted on 10/4/12 at 05:17 PM |
If it's anything like the blackbird clutch, then all I did was bolt two of the clutch discs together to lock both halves of the basket together.
Then put it in gear and put the handbrake on. That was enough to get mine on and off.
Sun Tzu, The Art of War
jakeob
posted on 10/4/12 at 05:23 PM |
Well Just been to Machine Mart and got a cheap Impact gun.
So gona try it in gear with the handbrake on then fire up the gun,
thanks for the replies
jakeob
posted on 10/4/12 at 05:26 PM |
Off Is anti clockwise right?
ReMan
posted on 10/4/12 at 08:24 PM |
Yes
www.plusnine.co.uk
jakeob
posted on 10/4/12 at 08:32 PM |
Any Ideas where i can find a new Bearing for the clutch basket
part no 93310 228s5 00
smart51
posted on 10/4/12 at 08:38 PM |
Do you want the cage with the needle rollers from where the outer basket slips over the crank? I have a serviceable one in my pile of useless junk if
you want it.
ReMan
posted on 10/4/12 at 08:42 PM |
Is that the problem then?
Did you get the nut off?
http://www.yamahamotorcyclespares.co.uk/spares/search.asp?uID=0&search=93310228s500&Search=&task=search&option=com_search&Itemid=5
9&modelID=&matchType=allwords&universal=1
www.plusnine.co.uk
jakeob
posted on 10/4/12 at 08:48 PM |
Yes Got off with the new gun no problem.
Fitted the new basket, much less play on rotation. But still to much movement back and forth, so i think a new bearing is in order.
Thats a great link thanks
ReMan
posted on 10/4/12 at 09:01 PM |
Where are the R1 experts?
I'm not, but I've got a feeling that a small, (mm's not microns) amount of forward backward play may be OK on there.
Might be worth getting this confirmeed before you splash out on a bearing unneccessarily
www.plusnine.co.uk
