Author: Subject: BEC rear engine - gear change setups.
T66
posted on 22/9/12 at 05:51 PM Reply With Quote
Any chance of folks pics of their setups please , intend to do a rod change to the lever, but also run a Pingel solenoid in that linkage.
Links to build blogs are champion. Thanks.
number-1
posted on 23/9/12 at 01:15 PM Reply With Quote
Hello mate. Ive got a push pull cable change for my rear engine BEC. If you need any pics of it let me know
Jon Ison
posted on 23/9/12 at 01:37 PM Reply With Quote
I used rod on mine moons ago, doing it again a push pull cable would be my choice.
number-1
posted on 23/9/12 at 01:46 PM Reply With Quote
Jon, why wouldnt you use a rod again? Any issues or just personal choice?
Jon Ison
posted on 23/9/12 at 02:29 PM Reply With Quote
1 cable will replace several rods & pivots, each one puts potential slack into the linkage ?
T66
posted on 23/9/12 at 02:49 PM Reply With Quote
What I'm proposing is to run my Pingel solenoid mounted somewhere, probably behind the gearshaft
Pictures are good, then I can copy.
It's the design of the stick mount & bracketing I'm after.
Cheers guys.
BobM
posted on 25/9/12 at 11:28 AM Reply With Quote
I originally used a paddle shift with 3m push-pull cable but it was a PITA so now have a stubby lever with a short bacle going straight back. Works great. Pics etc. on my blog.
Not very Locost but very BEC
