smart51
posted on 28/8/15 at 12:36 PM |
alternatives to a flat roof...
... That are not a pitched roof. We may be taking on a project house that needs the flat roof replacing from the joists to the parapet wall. The
house is a semi an would look strange if we build a traditional pitched roof on our side only. Since we're doing the entire thing, we can do
anything. I don't really want felt that will need to be done again before long. What other options are there that will only need doing
once?
The roof is about 8m by 8m
[Edited on 28-8-2015 by smart51]
r1_pete
posted on 28/8/15 at 01:04 PM |
There are Butyl and EPDM rubber systems available, I've seen guarantees of 20 years, and 40 year life expectancy, it is generally fitted in one
piece so no seams to deteriorate.
loggyboy
posted on 28/8/15 at 01:33 PM |
So you mean alternative coverings to a flat roof. as its either flat or pitched. There is nothing else...., until forcefields are invented.
As above, Sarnafil or Trocal are the big name brands of single ply membranes.
[Edited on 28-8-15 by loggyboy]
Mistral Motorsport
smart51
posted on 28/8/15 at 02:05 PM |
Not so much alternative flat roof coverings to felt, as alternatives to a flat roof or a conventionally pitched tiled roof. Is there any value in a
roof with a very shallow pitch or is it just a flat roof with a bit of a slope? If a standing seam metal roof, for example, is as durable on a flat
roof as with a gentle slope, we may as well make it flat.
Volvorsport
posted on 28/8/15 at 04:24 PM |
Fibreglass....
www.dbsmotorsport.co.uk
getting dirty under a bus
Rosco86
posted on 28/8/15 at 05:47 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=199457
From a few weeks ago
[Edited on 28/8/15 by Rosco86]
My Build Thread
rm0rgan
posted on 28/8/15 at 08:14 PM |
I have both a Fibreglass dorma roof and a really big (95 sq metres) EPDM roof (too big for fibreglass).
Both have 25 year warranties and the EPDM is designed to last 50 years. - EPDM is cheaper than fibreglass and if the bloke who did the fibreglass roof
did EPDM when we had it put down I'd have gone EPDM for both. In terms of performance, both are clearly waterproof but the fibreglass roof
creaks when really cold whereas the EPDM one doesn't.
Some good installers out there but check references of their work and get a few quotes as prices can vary significantly.
Sigs are uncool.
RoyM
posted on 29/8/15 at 06:21 AM |
Another vote for EPDM - put it on my balcony a couple f years ago. Easy to install yourself and realy tough. All problems solved. If you're
ordering get some extra - rubber vsheet has loads of uses in the car!!
smart51
posted on 29/8/15 at 06:28 PM |
So lots of support for leaving it as a flat roof rather than putting a shallow pitched roof on there. I do quite like the idea of EPDM. Partly
because it will be a single sheet with no joins. does it outlast a standing seam metal roof?
JC
posted on 29/8/15 at 10:38 PM |
I seem to recall that the shallowest pitch should be about 5 degrees. You could always have one of these trendy modern looks where the walls are
quite thick, and higher than the sloping roof. I know, a picture would help...!
