nick-york
posted on 9/12/17 at 05:51 PM |
Pinto hole query !
Hi I'm in the process of fitting a new dashboard and trying to work everything out before I start dismantling different sections .I'm
fitting a digi dash so the old clocks and Speedo cable are now obsolete. I gavent disconnected the Speedo cable from the gearbox yet or even looked at
how it fits ! But I would imagine it's going to leave a hole that is going to need blocking off .Is there a blanking off plate I can buy or is
it going to be a home made job or what ? Any help much appreciated. Cheers - nick
melly-g
posted on 9/12/17 at 06:00 PM |
Mine has been on the car for 10+ years without any blanking plug!
Not sure that is right though, it's not leaked any oil yet!
It's coming out soon for an engine change so I'll check it out then.
gremlin1234
posted on 9/12/17 at 06:23 PM |
if I remember correctly, its possible to get blanking plugs. but also a coin fits, and can be held with a circlip
steve m
posted on 10/12/17 at 09:17 AM |
I presume its a ford gearbox. and if so you do not need a blanking plate or cover, as it has a seal in there were the speedo drive comes out, no oil
should leak out,
steve
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
nick-york
posted on 10/12/17 at 05:41 PM |
Yes it's a ford type 9 gearbox .forgot to mention that .Thanks for the help everyone .An easy and straightforward job then ! Well that will be a
first !
[Edited on 10/12/17 by nick-york]
