adrianreeve
posted on 1/5/24 at 02:25 PM |
Making an airbag-equipped steering wheel IVA compliant?
I plan to use the OEM steering wheel for my MX5 based Haynes Roadster - how do people go about making it IVA compliant? I’ve removed the airbag, but
that obviously leaves a big hole inside the airbag case - do I need to fill it with foam or something? Guess I have to remove the airbag text from the
cover too?
Adrian
[Edited on 1/5/24 by adrianreeve]
40inches
posted on 1/5/24 at 03:46 PM |
I disarmed mine, and that was it. No mention at IVA.
posted on 2/5/24 at 10:13 AM |
Never done this (or even considered it).
I'd imagine if it's "disarmed" (as in the explosive charge can't be set off) it would be OK.
Next step would be to remove the explosive charge and probably the airbag itself. I'd think very carefully about doing it, to avoid potential
injury.
I did SVA (forerunner to IVA) many moons ago. I don't remember being able to contact the test centre to ask questions like that though.
Does the IVA manual offer any guidance?
Charlie_Zetec
posted on 8/5/24 at 09:46 AM |
injury.
Exactly this.... the airbag will be triggered by an electrical signal upon impact, so by disconnecting it from any current source, you've
essentially taken away the firing pin. BUT, similar to a lifejacket, it will still be "armed" and could still potentially activate (chances
are very, very slim - but never zero). I'd investigate how the airbag itself could be dismantled or the gas canister removed to avoid the risk.
Can't comment of if or how this may even be possible, but it would be my approach....
FEZ1025
posted on 9/5/24 at 12:53 PM |
Undo the 2x 10mm screws holding the centerpiece in, put it to one side for 30 minutes (JIC) then flip it over, using a flat screwdriver prize the
little round tabs off & remove the explosive part, throw in open fire or apply 12V to the wires NO!! JOKE!! Do not do that part.
But once that bit is off, you can then remove the bag itself easily, I have always then used a soldering iron to remove the word Airbag from the front
of the pad, however the last 2 IVA's I was told that wasn't needed, but that might just have been my inspector & I still would.
[Edited on 9-5-2424 by FEZ1025]
