irvined
posted on 23/2/05 at 04:52 PM |
Fuel Tank Sender
Hello,
I've got an ali fuel tank from GTS, its got a top mount 6 hole fuel sender hole, but, i've no idea what sender will fit in it, I've
got one which nearly fits but the bit where the float joins onto the body is too large to fit through the hole.
Any ideas?
Ben_Copeland
posted on 23/2/05 at 04:59 PM |
Try asking darren ??
I've got the same hole in my plastic tank.
Trying to think what sender it was now.......
I bought mine from Leugo... have a look on their website. it's clearly marked as 6 hole sender
HTH
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
flak monkey
There should be a notch in the body of the sender to allow you to fit it through the hole...maybe!
see page 8 of this...
http://www.lowtension.com/performance_%20kit.pdf
Of course your sender may be nothing like that!
[Edited on 23/2/05 by flak monkey]
Sera
http://www.motosera.com
Peter Cowley
posted on 23/2/05 at 05:08 PM |
I have a brand new sender that came with my vdo kit from low tension - they are £45 new.
Looking for £30.
Regards.
Peter.
Toolbox_USA
posted on 24/2/05 at 06:08 AM |
Try a marine application, like Centroid.
Centroid Fuel Sender
Definately will fit!
I think they are 240-33 ohm, though. Your gauges would have to be matched up.
Jeff
irvined
posted on 25/2/05 at 12:46 AM |
Sweet, will give the luego one a try.
Cheers guys
dozracing
posted on 25/2/05 at 05:30 PM |
Sender comes from Smiths or ETB should fit straight in. Cost is about £18 if i remember correctly.
Kind regards,
Darren
