Author: Subject: ticking noise
hurf69
posted on 4/3/05 at 04:45 PM Reply With Quote
ticking noise
hi all hope someone can help .
i stated my engine for first time today after 3 months and the engine at idle seems to have a ticking noise ,seems to be coming from near the rocker casing.
anyone have any ideas what it could be.
cheers josh
p.s its a 1800 zetec
theconrodkid
posted on 4/3/05 at 04:55 PM Reply With Quote
probly a tappet filling with oil,it should go away soon,you using the right oil?
who cares who wins
pass the pork pies
DarrenW
posted on 4/3/05 at 04:58 PM Reply With Quote
Do they have hydraulic tappets? One sticking a bit?
What year / donor etc. Im not zetec expert but thought there were black tops and silver(??) tops. If you post exact model one of the experts should be able to help. I assume it was OK before. Has the car been stored fo rthe Winter etc.
My BMW engines used to tick (E30 straight 6), it was injector rail. The test was to hold throttle open at about 3K, tick was not audible, let go and if it became audible on tickover it was the rail and nowt to worry about. Otherwise it was tappets.
hurf69
posted on 4/3/05 at 05:04 PM Reply With Quote
thanks both
its a 95 silver top 1800 ,ill try the 3k rpm thing . thanks
it has been stood for winter im using the right oil .
thanks josh
zetec
posted on 4/3/05 at 05:42 PM Reply With Quote
The valves on that engine are a little prone to sticking. I get the same thing sometimes after it has not been run and as conrod says suspect due to a lifter, one warmed up no noise and performance never seems affected.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
hurf69
posted on 4/3/05 at 06:00 PM Reply With Quote
thanks
Ben_Copeland
posted on 4/3/05 at 06:21 PM Reply With Quote
Its the same with the vauxhall 16v.... tappets most times or worn cam!
The best way to stop it is to take the lifters out, take them apart, clean it all out and fill back up with oil. Solves the problem 9/10 times
Ben
Locost Map on Google Maps
Enter Your Details Here
NS Dev
posted on 5/3/05 at 09:47 AM Reply With Quote
or as was mentioned, could just be the injectors! Depends on how loud the "ticking" is!
