Author: Subject: air filter
hurf69
posted on 13/3/05 at 09:10 PM Reply With Quote
air filter
any help /ideas welcome
my 1800 zetec in a 7 type car has a k&n filter on it but the filter is placed infront of the cam gear cover but behind the radiator so my engine must be gettin warm air . i am willing to buy new filter and ducting etc but where do i put it to get cold air as not much room in front of rad or under bonnet full stop.
what have you all done.
cheers josh
big_wasa
posted on 13/3/05 at 09:17 PM Reply With Quote
Hi,have you got the standard induction setup??
To go of subject a touch....Have you needed to shorten the sump to get the zetec in and what gearbox tou using..
I would love to come and have a look/chat one day as im just up the road
ethomas
posted on 14/3/05 at 09:08 PM Reply With Quote
You could run the Filter to outside the bonnet completely, and have it poking out on the opposite side to the exhaust, nice cold air and potential for a ram air effect at high speed.
Just an idea.
Ed
hurf69
posted on 14/3/05 at 09:22 PM Reply With Quote
big wasa i think it is the standard induction just with a k&n filter.
im a bit of a cheat and bought the luego ex demo so did not build the car . the box is an mt75 and sump im sure is the standard 1800 zetec one .if you want to come over you are very welcome anytime.
cheers josh
ethomas i think thats a very good idea but may look abit funny (who knows).
what do you mean by ram air
josh
ethomas
posted on 14/3/05 at 09:50 PM Reply With Quote
Ram air is using a scoop to force air into the system at a higher pressure at speed. It will not turn your car into a turbo, but can help at high speed. I would not mount a standaard Zirbox outside a car, but an induction kit mounted under an aluminium scoop could look nice.
Ed
hurf69
posted on 14/3/05 at 09:58 PM Reply With Quote
see what you mean a pipercross viper kit could do the trick
hurf69
posted on 14/3/05 at 10:15 PM Reply With Quote
just another question.
i see when you buy an induction kit you specify which car it goes on , why is this.
greggors84
posted on 14/3/05 at 10:21 PM Reply With Quote
Just so that you get the right mounting kit. Alot of aftermarket filters are the same for similar cars, but just have a different base plate or moutning points so they fit in that paticular car.
Chris
The Magnificent 7!
