Author: Subject: Brake fittings source / Rubber trim source
tks
posted on 14/4/05 at 05:11 PM Reply With Quote
Can any one give me
a link to an place for the brake fittings needed between the M/C and the reservoir???
and also for that hose??
also i need to know where to buy the rubber trim needed for the mudquards
front en rear..
TKS
saigonij
posted on 14/4/05 at 06:08 PM Reply With Quote
i think the supply feed is m12 fittings and we got a motor factor to get us some approved rubber brake pipe, with the numbers down it. i got the motor factors to flare two 10cm lengths of copper brake pipe, put the m12 over the top and screwed them in to the master cylinders.
then just put the rubber hose over the top and jubilee clip them on.
hurf69
posted on 14/4/05 at 06:39 PM Reply With Quote
wollies is best for trim ets they are on links page
