Gav
posted on 11/10/05 at 09:32 PM |
GTS Locost de-dion plans
finally recieved the gts plans and ive started work on the rear, however i have already built the basic "book" chassis using the mcsorley
plans, apart from the rear end as i am going to use the dedion.
Comparing what ive built to the GTS plans, the GTS plans seem about 20mm higher from the bottom of the lower rails to the top of the rear bulk
head.
I have checked the measurement of upright tubes that the trailing arms attach to and this seems fine so basically the plate the top suspension bracket
is attached to will be 20mm lower and about 10mm further forward than it would of been.
I assume someone has done the same as i have and encounterd the same problem.
it would be good to have someone else opinion.
regards
gav.
Ben_Copeland
posted on 12/10/05 at 05:38 AM |
Just make sure nothing hits the chassis rails under the extreme movement (something it's probably never gonna see anyway)
U can always modify the de-dion brackets to suit.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
flak monkey
posted on 12/10/05 at 06:11 AM |
IIRC the rear bulkhead is 25mm higher than the standard locost one to make it easier to pass SVA with a 4 point harness installed as it brings the top
harness mounting points at about the right level.
Sera
http://www.motosera.com
Gav
posted on 12/10/05 at 08:11 AM |
ah right, cheers guys
gav.
