ethomas
posted on 21/10/05 at 04:40 PM |
Paint vs. powder coating
I have a pair of tubular manifolds for my V6, and am debating whether to go for exhaust paint or powder coating.
The cost of powder coating is about £40, is it a worthwhile upgrade over a painted finish?
Ed
posted on 21/10/05 at 05:33 PM |
Will powder coating take the heat?
owelly
posted on 21/10/05 at 05:53 PM |
IMHO power coatimg (and plastic coating) will not stand the temperature. You need stove enamalling (sp?) or VHT paint.
I prefer paint because it is easy to recoat if you need to modify/repair stuff.
http://www.ppcmag.co.uk
NS Dev
posted on 21/10/05 at 06:02 PM |
I had a supposedly heat resistant powder coated exhaust manifold once. On the first "proper" run it all burnt off!
zzrpowerd-locost
posted on 21/10/05 at 08:21 PM |
powercoating will burnt off, as its basically plastic!
Glan Noye
posted on 21/10/05 at 08:27 PM |
Ceramic is good Expensive though! http://www.camcoat.u-net.com/Exhausts.htm
Mike R-F
posted on 21/10/05 at 10:30 PM |
Go for a good quality wrap instead. Looks good & helps gas flow.
ethomas
posted on 22/10/05 at 11:51 AM |
Right, that is an easy choice then.
Thanks guys ![](/images//smilies/smile.gif)
