Author: Subject: Copper fuel pipe
whitestu
posted on 27/1/06 at 02:49 PM Reply With Quote
Copper fuel pipe
Hi
I'll be using 8mm microbore pipe for the main fuel run, P clipped every 250mm with plastic P clips.
My question is does the pipe need to be covered with rubber for the SVA, or is it OK as long as it isn't actually touching the chassis, even though it will be very close?
Stu
mookaloid
posted on 27/1/06 at 02:53 PM Reply With Quote
as long as it doesn't touch the chassis and nothing can move to rub against it or crush it (eg axle) you should be ok.
no need to cover the whole thing in rubber.
whitestu
posted on 27/1/06 at 02:55 PM Reply With Quote
I'll probably put something over it where it goes through the chassis at the back, but there will be no moving parts close to it.
Stu
zetec
posted on 27/1/06 at 03:14 PM Reply With Quote
Thats what I did...as it comes out from the tranny tunnel I slipped over a length of 1/2" bore rubber pipe Probably of no use but might protect the copper if it gets squashed.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
andyharding
posted on 27/1/06 at 03:32 PM Reply With Quote
I used copper, no cover and no problems.
Tigger
posted on 27/1/06 at 09:35 PM Reply With Quote
What's with the "As long as it doesn't touch the chassis" bit?
Never heard of that one before!!
Tigger
Syd Bridge
posted on 28/1/06 at 11:26 AM Reply With Quote
A nice little addon is to put coloured heat shrink over the fuel pipes. (Heat shrunk, of course! )
Looks pretty, too.
Syd.
NS Dev
posted on 31/1/06 at 11:05 AM Reply With Quote
Tigger
No, nor me, they are usually attached to the chassis unless you have some sort of magic powers!
wilkingj
posted on 31/1/06 at 10:25 PM Reply With Quote
I put mine in split convoluted tube, the sort you use for wiring looms.
Or how about a bit of garden hosepipe. (Copper pipe inside the hosepipe... not hosepipe for the fuel )
I would protect it, mainly from the weather / road salt, if for no other reason.
[Edited on 31/1/2006 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
