Gav
posted on 21/3/06 at 09:24 PM |
GTS Locost de-dion plans & roll hoop
Just a note to anyone planning to use the GTS locost plans and Roll hoop.
The plans for the rear end where the tank sits has 2 webbing plates cut at 45 degrees at either end however now ive added the roll hoop the bottom of
the backstays have nothing to sit on so these really need to be the full width of that section.
which wasa bit of a PITA as i had already welded in the webbs
you can see more detail Here
Triton
posted on 22/3/06 at 08:55 AM |
You could also add a bit of rhs under those corner plates to stiffen things up where the rear stays mount.
I think from memory the plates will need shaping to allow the rear panel to fit nicely aswell....buzz a sander round them to knock the edges off.
www.tritonraceseats.com
www.hairyhedgehog.com
Gav
posted on 22/3/06 at 09:13 AM |
I was thinking of adding a gussest from the outside edge tot he outside upright tube, ill have to see when i get my bodywork
Micael
posted on 7/4/06 at 10:57 AM |
I love your dampers.
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
Gav
posted on 7/4/06 at 11:39 AM |
Just set like that until i get my springs from GTS...
