Author: Subject: Which adhesive for Cycle Wings?
craig1410
posted on 5/4/06 at 12:13 PM Reply With Quote
I remember Darren talking about using Loctite "Seriously Strong Stuff" for gluing the cycle wings to the brackets but I can't find this particular adhesive listed anywhere. Can anyone tell me where to find it? I think he also referred to it as "No More Nails" but the only one I can find is Unibond No More Nails and I have tried it before for DIY use and found it to be less than great.
Thanks,
Craig.
Mr G
posted on 5/4/06 at 12:20 PM Reply With Quote
Personally I think you want to be using Polyurethane Adhesive. I would'nt use no more nails??!?
PU is like $hit to a blanket but still gives - and if your careful and patient 'can' be cut and removed if required
Available from all good local builders merchants etc failing that lolocost etc
DarrenW
posted on 5/4/06 at 12:22 PM Reply With Quote
I used Wurth bond & seal for mine. No probs so far.
2 lengths of hosepipe gaffer taped to wheel. Steel straps bent round on top of hosepipe. Cleaned the steel up and applied adhesive. Cleaned arch placed on top and held in place overnight with masking tape. Once set removed wheel and hosepipe then aplied more adhesive to the underside. Worked a treat.
BKLOCO
posted on 5/4/06 at 12:26 PM Reply With Quote
Yep "Seriously Strong Stuff" works a treat.
Available from B&Q Made by EvoStick.
Alternatively you could try Wikes "Ultimate Adhesive" This S**t will even stick surfaces when the're wet.
Originally posted by craig1410
Thanks,
Craig.
Mr G
posted on 5/4/06 at 12:38 PM Reply With Quote
Lol, check this out.....
Bostik homepage product listing HERE
Hover over 'Trade' on the left hand side then over 'Grab Adhesive - Trade' ....Bottom product displayed (Literally)
[Edited on 5/4/06 by Mr G]
smart51
posted on 5/4/06 at 12:51 PM Reply With Quote
I used PU adhesive on mine and the wings have stuck on just fine, even when the bracket itself snapped,
posted on 5/4/06 at 03:07 PM Reply With Quote
PU adhesive for us too....
Texflex, Tigaflex, Sikaflex... they are all very similar...
craig1410
posted on 5/4/06 at 08:39 PM Reply With Quote
Thanks Guys, I already have some PolyFlex PU adhesive which I used for the panels so I might use that. I think I'll get some of the Evostik SSStuff though as that was what Darren himself recommended although I'm sure he said it was Loctite. Thanks BKLOCO for pointing me towards B&Q!
Craig.
scotty g
posted on 9/4/06 at 05:42 AM Reply With Quote
Deffinately Evostick, i have some in the garage and damn its good.
I'd have to describe it as seriously strong!
Triton
posted on 9/4/06 at 08:16 AM Reply With Quote
Gripfill is cheap and sticks like stuff to blankets.
www.tritonraceseats.com
www.hairyhedgehog.com
