TimC
posted on 10/5/06 at 02:04 PM |
Brackets for braided brake hose join?
Hello GTS builders
Can you tell me if the Panther chassis has brackets welded to act as the 'bulkhead-type' join between solid and flexible brake hoses?
Ta
TC
nludkin
posted on 10/5/06 at 02:20 PM |
I do not believe so. They are available from GTS in the brake kit and are riveted to the chassis.
I ended up going up to B and Q, getting an ally bar, cutting it down, rounding it off, drilling a few holes and voila.
Not as elegant as laser cut brackets but you never really see them anyway.
TimC
posted on 10/5/06 at 02:28 PM |
very true - My MK was fitted with them in the same way that you have - it just strikes me as something that is an easy addition for the chassis
builder to fit??
