robby
posted on 3/7/06 at 03:57 PM |
clutch master cyl. hose
i've got a vfr 750 rear brake master cyl. as my clutch master cyl; anyone know if the rubber hose from the resevoir has to be marked to pass the
test, or will the original do? cheers!
tks
posted on 3/7/06 at 05:31 PM |
if its the original
i think the sva man will see it else i would tell it him.
else let him proof that it isn´t the right one
Walter
JohnN
posted on 3/7/06 at 05:53 PM |
ABSOLUTELY!
If the hose has no marks to prove its provenance it will fail, same for rubber fuel line.
The official failure wording will be:
"The fuel and hydraulic pipes are subject to a corrosive environment likely to cause premature failure"
The moral of this tale is - don't buy such stuff unless it can be correctly identified and fit for purpose
Snuggs
posted on 3/7/06 at 07:17 PM |
If it is for the clutch then it should not need to be marked as it is not a critical safety component.
My clutch pipework is half copper and half original rover plastic tubing but there are no markings on it and it passed OK![](/images//smilies/bigsmile.gif)
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
robby
posted on 5/7/06 at 07:50 AM |
cheers!
