Author: Subject: Diff question
mookaloid
posted on 6/7/06 at 09:36 AM Reply With Quote
Diff question
Anyone recognise this diff? not seen the rear mountings before....
Is it a 7 or 7.5"?
chockymonster
posted on 6/7/06 at 10:21 AM Reply With Quote
It doesn't look like a sierra diff
Those rear mounts look like a bit solid!
[Edited on 6/7/06 by chockymonster]
posted on 6/7/06 at 11:28 AM Reply With Quote
its similar but different to a sierra one, id guess its a bigger ford, maybe a scorpio? Says 2 litre auto on it, which is a common engine/box in the scorpios.
peterriley2
posted on 6/7/06 at 01:28 PM Reply With Quote
im pretty sure its a scorpio, usually come in 4.27 ratio. would be usable if mounts were made specifically for it. theres a guy selling them on ebay for £150 bin.
Joel
If you dont respect yourself, dont expect respect from anyone else
Live your dreams, dont dream your life
Women only want you for one thing- everything!
mookaloid
posted on 6/7/06 at 02:34 PM Reply With Quote
Ah so it's probably a 7.5" which is not so good cos the case will be much bigger than my 7". I like the sound of 4.27 ratio though, the acceleration would be awesome
peterriley2
posted on 6/7/06 at 02:41 PM Reply With Quote
umm acceleration would in theory be awesome, but in practise it would mean you'd have to change gear more, meaning you lose the added speed you would be gaining. its a kind of 1 step forward 2 steps back kinda thing.....
Joel
posted on 6/7/06 at 04:00 PM Reply With Quote
depends on the track, i suspect that a 4,27 would be well suited to hillclimbing. Im sure mark knows how to bang it through gears fast
Liam
posted on 6/7/06 at 05:03 PM Reply With Quote
It's a late bug-eye scorp 7.5". Identical to a normal 7.5 except for the rear cover as far as i'm aware, and yeah they do come in some low low ratios.
Liam
fully sideways
posted on 6/7/06 at 06:37 PM Reply With Quote
Mark, What motor are you running as the rev range and power will dictate how fast you have to grab the gear level..
I am currently running a 4.6 and previously had a 5.3...
Andrew
Is throttle wide open ?
mookaloid
posted on 6/7/06 at 08:00 PM Reply With Quote
Thanks Joel, I have on occasion been known to get gearchanges right!
I was running a 3.62 but the 3.92 made a noticable diffence to my times.
As far as I know 3.92 was the lowest ratio ford made as standard. I know I can get specialist 4.1 and 4.4 CW/P sets but the price is staggering - And you have to fit them!
Andrew, I am running a pinto with V6 type 9 box. I guess you are running an escort axle so you can get those ratios.
Mark
