graememk
posted on 11/7/06 at 10:02 PM |
running very hot
ok well i'm running to hot, i have a micra rad on the car and if i run the fan it blows cold air and the rad even cool yet the water comming out
is still very hot, if i stop the fan the rad quckly warms up
do you think i need a bette rad ?
edit nissan 1.8t
[Edited on 11/7/06 by graememk]
cct7kitcars
posted on 11/7/06 at 10:08 PM |
what engine you running
cct7kitcars
MkIndy7
posted on 11/7/06 at 10:35 PM |
It sounds like a water flow problem.
If you turn the fan off the heat "appears" in the rad probably by conduction through the hoses etc.
But when you switch the fan on this removes the heat gain your getting through conduction thus appearing cold.
I'd look at how your hoses are connected and if there could be any air locks.
Broadside Motorsport
posted on 11/7/06 at 10:40 PM |
check the stat and as said, check the rad. also check all the hoses lead so as the header is at the top so the air can get out. I had same problem
with my xr2, the heaters blew hot, the rad got hot, but would over heat. turned out some "muppet" had used "rad weld" to fix a
leak and it had actually sealed the stat shut! took it out and just ran with out a stat being as its summer anyway. Will just put a new one in my new
engine build.
froggy
posted on 12/7/06 at 11:33 AM |
get a cheap digital laser thermometer they are dirt cheap and then you will know exactly what temp the engine block ,stat top hose etc
posted on 12/7/06 at 12:01 PM |
The original Micra rad fan actually sucks air through the rad not blows (have I read your post wrong, or have you fitted an aftermarket fan?)
A couple of things you could do, if you haven't already;
1 - Fit a manual over-ride switch for the fan.
2 - Add a bottle of water wetter to your coolant.
3 - Duct ALL the air entering your nosecone through your rad.
HTH
Phil
John Bonnett
posted on 12/7/06 at 04:27 PM |
It certainly does sound as if there is an airlock in the system. I remember when I screwed my C.......m together (sorry for the dirty word) it took
several goes before all the air had been removed from the system. It appeared to be full of coolant but it still boiled. One other point not already
mentioned is to make sure the radiator is fully boxed in so that all the air coming in through the grille has to pass through the rad.
Let us know how you get on.
John
posted on 12/7/06 at 05:10 PM |
Caterham isn't a dirty word on here. At least not to most of the forum members.
Phil
fully sideways
posted on 13/7/06 at 06:07 PM |
hello Graeme,
just to clarify, is it the rad fan or the heater fan that is blowing cold ??
Cheers Andrew
Is throttle wide open ?
