Author: Subject: Dual brake oil reservoir fittings
Gav
posted on 6/9/06 at 02:45 PM Reply With Quote
Just about to hook up all my brakes.
Ive got dual master cylinders fed from a dual brake oil reservoir however the problem is the reservoir has what looks like push on rubber tube fittings but the master cylinders accept a screw in fitting.
What should i use to connect two, or how has anyone else that has this setup solved it?.
chockymonster
posted on 6/9/06 at 02:59 PM Reply With Quote
2 copper tails into the master cylinders with flared ends
Rubber pipe from resevoir to tails.
Gav
posted on 6/9/06 at 03:45 PM Reply With Quote
Yeah i did think of that one but then i thought it wouldnt do with the pressure, but then again the only pressure i guess it has to deal with is the oil being fed back up when the pedal is released which i would imagine is bugger all...
humm seems easy now its all wrote down
