Author: Subject: gts de-dion
ch1ll1
posted on 16/10/06 at 07:06 PM Reply With Quote
gts de-dion
hi all
is the gts de-dion set full length drive shafts or shortened ones?
cheers paul
flak monkey
posted on 16/10/06 at 07:07 PM Reply With Quote
Uses standard driveshafts. Unless you specifically buy the narrower one used for the challenger.
Sera
http://www.motosera.com
ch1ll1
posted on 16/10/06 at 07:08 PM Reply With Quote
cheers for that
do you know the spacing between the trailing arms?
is it more or the same as book?
flak monkey
posted on 16/10/06 at 07:11 PM Reply With Quote
Same as book as far as I can remember.
The GTS chassis is essentially a book chassis, slightly modded behind the rear bulkhead to allow more clearance for the de dion on full droop.
Sera
ned
posted on 16/10/06 at 07:54 PM Reply With Quote
my gts dedion fitted my book chassis pickup points for the trailing arms, i fitted the panhard rod mount when i already had the axle but its not hard to position it once in situ.
Ned.
beware, I've got yellow skin
