nludkin
posted on 22/10/06 at 06:17 PM |
Almost finished my GTS W7DE
Well, there's still lots of trimming to be done and cables to be prep'd for SVA, but the end is finally in sight.
I had to do some work on my everyday car and needed the garage, so I thought I would move the kitcar up the drive for the first time and get some
piccies :-)
Almost there - Front
t.j.
posted on 22/10/06 at 06:41 PM |
looks great in black....
Hope the black stuff on the driveway is not coming out of yours.
[Edited on 22/10/06 by t.j.]
scotty g
posted on 22/10/06 at 07:02 PM |
Looking very nice matey.
As discussed in one of Flak Monkeys threads, your side panels will need a little bit of a trim. The front lower area that sticks out beyond the nose
cone radius.
Either cut it back just behind the wishbone or drill out the rivets underneath, pull the sides under a tad and re-rivet.
Good luck with the SVA dude.
Cheers.
flak monkey
posted on 22/10/06 at 07:08 PM |
Looking excellent And I still think they look awsome in black! Hopefully mines not far off that stage.
Whens the SVA booked for then?
Sera
http://www.motosera.com
Johnmor
posted on 22/10/06 at 08:33 PM |
Cool
Looks good, like the lights.
looking at the front indicators though, you may need to do something as they should be visable at an angleof 80 degrees from the front so the tyre may
hide their view. Just mention this because i know someone else had the same problem with indicators mounted on the headlight mounts.
donut
posted on 22/10/06 at 08:43 PM |
Very cool!
posted on 22/10/06 at 08:53 PM |
You'll need some proper headlights for SVA. Other than that, it's looking good.
Phil
nludkin
posted on 23/10/06 at 09:21 AM |
Thanks for the positive comments guys. Luckily the oil isn't coming from the car, it was the bloody oil filter on my missus's car that
dropped it during it's oil change.
I read the thread the other day on the side panel issues (Needing pulling in) and will tackle that one shortly. A slight concern is that there is
still about 20mm of the bottom tube showing under the nosecone, does this count as a sharp edge?
I will have to change the headlights for SVA and I am considering making a metal standoff for the indicators to bring them out to the required 80
degree visiblility.
Hopefully after these issues are addressed I will fix the seats in properly and apply for the test :-)
Deckman001
posted on 23/10/06 at 04:58 PM |
So why can't the headlights be used for Sva, I was told these had been through the test all ready and had passed with a slight mod concerning
turning the lens ??
Jason
nludkin
posted on 23/10/06 at 05:20 PM |
I believe the SVA manual states that the headlights must dip down and to the right, but these don't as they are motorbike headlights and only
dip downwards as I found out after I bought them. Doh!!
If anyone knows of a sure way of passing with a small mod, I am up for giving it a go.
posted on 23/10/06 at 05:28 PM |
Even if you could get the beam pattern right, they would still fail because they are incorrectly marked. No reson you can't re-fit them after
SVA though.
Phil
Deckman001
posted on 23/10/06 at 05:46 PM |
Cheers phil, you know how to cheer someone up don't ya !! Oh well
Jason
