scoop
| posted on 2/9/07 at 12:48 PM |
Gts wide wishbones
Will they take the Cortina upright and therefore the Raceleda set up ( which is what im reallly thinking of) in an attempt to reduce weight?
fesycresy
| posted on 2/9/07 at 03:42 PM |
I believe, but I'm no GTS expert, that they have different wishbones for Sierra and Cortina.
Lyn.
scotty g
| posted on 2/9/07 at 05:22 PM |
I thought you could use either with the GTS bones,
give them a call, if they don't do them as standard then they would be able to make some for you anyway.
Cheers.
flak monkey
| posted on 3/9/07 at 11:43 AM |
Sierra and cortina wishbones are different, and both available as far as i know. The bottom ones are the same, but the top ones are different
lengths.
Sera
http://www.motosera.com
scoop
| posted on 3/9/07 at 03:05 PM |
Bugger. Was looking good until you turned up Flak man. Cheers for that
