Hi Everyone,
I have my IVA retest tomorrow, failure points were..
CO content above limit.
12v aux socket didn't meet radius requirements.
Couple of cable ties needed turning round.
Carpet on bulkhead touching column.
Ive now sorted these, do I need to present the car with a full tank of fuel again?
Thanks,
Shaun
As far as I know they only check the items that failed. tank full is a leak type test.
Cheers for that, car isn't going to be registered for a fair while after IVA so I didn't want to fill it up only for me to have to drain it all after!
It failed on carpet touching the steering column?
Which IVA station was that at?
All passed now! Station was Kidderminster
Thanks guys,
TBH I think I will register it now, not sure how long it usually takes anyway! I started the build exactly a year ago today which was a
coincidence!
Josh was a fair tester, although the test did take the full 6 1/2 hours. Keith did the retest and I got the feeling it would of taken him half that
time if he had done the test!!!
Nowt really to look out for, although one thing Josh was hot on was exterior projections and enough thread showing after a nut. Everything else was as
you would expect in the manual.
Thanks again,
Shaun
well done on the pass, now get it on the road for some factor
[Edited on 6/3/15 by Johneturbo]
Hehehe!
Does the first reg fee (£55) and tax (6 months 126.50) have to be separate cheques? Who do they need to be made payable to - DVSA?
Thanks,
Shaun
