1 pair Dynalite calipers 120-6806 4 pot lug mount with brackets to fit mk2 Escort uprights, with new pads compound E and D.
£150.00 ono plus p&p.
1 set (well i say set read on) of 310mm discs with Powerlite calipers and brackets and disc bells to fit mk2 escort, however one of the calipers has
had some of the material removed on the outside edge, to use it wouldn't bother me but some it would, so i have priced the kit incase you want
to buy a new caliper, cost me £650 a few years ago.
£175 ono plus p&p
[Edited on 13/1/09 by philw]
What disc width are the dynalite calipers for?
i tale it neither of these will fit cortina uprights?
or will they? if so i may be interested
20.6mm disc for the 120-6806 Dynalite apparently.
The 310mm set come with Mintex 1144 pads.
They should fit cortina as well. Both escort and cortina used M16 calipers as original fit....however the brake discs were different offsets.
Wouldnt swear to it though...
Bump!
Price reduced.
What wheel size would the 310mm disc fit under ? Are they vented or solid ?
