Pair of seats. Not used. Very similar to the MK ones.
£140 + delivery.
Image deleted by owner
[img][/img]
Just to say i bought a pair of these seats a few weeks ago for a simular price. Got this first one in the car today and am very happy with it.
- Fit very well in a narrowbody westfeild.
From the advert:-
Overall height 860 mm
Upper back width 390mm
Lower back width 325mm
Upper leg width 365mm
Overall base width 375mm
Weight 4 .5kg
Nominal 310mm between fixing points
Daniel
I bought exactly the same type of seat of eBlag and they are good quality - slightly off topic, but how did you fit it? Mine has four mounting holes
(one at each corner) but the bottom of the seat extends underneath in a hump shape for your a*se...
Did you make a front and a rear mount out of box section, or just bolt to the floor as is?
Just to ad... the mounting points are at 31cm squared.
The 'hump' is taken care of with the runners.
SOLD- PENDING PAYMENT
