Got a set of GSXR 750 injectors spare. Will also fit GSXR600 throttle bodies. And probably loads more that take the Kehin injectors.
Decided to go with uprated injectors for the duratec and mount them direct into the head.
£40 posted
Will include modified fuel rail which can be easily changed to suit any throttle body spacing.
[Edited on 28/3/09 by flak monkey]
How can the fuel rail be modified to fit any spacing? I'd be quite interested if I can get it to fit K-series spacing.
Adrian
Its essentially 4 plastic bits which hold the injectors connected with short pieces of tube joined with 8mm fuel hose. So basically all you need to do
is change the lengths of the hoses to make it suit.
A piccie
Image deleted by owner
Open to offers. Going on ebay tonight
