Hi Guys,
Ok i have for sale my MK Indy fuel tank which is the plastic version.
The reason for sale is it has a small leak at the bottom of the tank, the hole is so small you cant even see it.
If anybody knows how to fix a fuel leak on a plastic tank or can even plastic weld or no's a plastic welder then here is a bargain for you.
I no longer need it becuase i dont no any plastic welders and couldnt be bothered doing the research on how to fix it, but i was told that the Plastic
Padding Leak Fix should work?????
I dont really no how much to sell it for so if you can make offers that would be great...........
u2u sent
