I've got a 1.8 Duratec in my workshop taking up space. Most parts except sump available if any one needs any bits ?
is it working order??
It was swapped as is was noisy on the top end. Thought I'd ask if anyone needed any bits.
need a flywheel if its not the dual mass type if poss please
I cant remember, I'll check it tomorrow and let u know.
thank you
have you got the starter motor and ht leads and coil pack, if you have it and i will fit a 2.0?
and if it is a single mass flywheel and goaty does not have it, let me know.
thanks
stuart
and the dipstick? please
stuart
thanks
stuart
what car is it from? I need the tensioner as found on mk3 focus' that goes where the power steering pump would be on the mondeo motors (ie the
top tensioner).
I'd also have the flywheel if single mass - but looks like I'm well beaten to that one lol.
Its from a Mondeo, flywheel is a dual mass, not sure what tensioners are on it. I'll have a look.
