New mocal 19 row oil cooler £60 delivered
New polo radiator £30 delivered
Akrapovic exhaust can, slip on with db killer £130 posted
Alfano pro £150 posted
oxford M/C battery charger/optimiser £30posted
franky,
have you any pic/dims of the rad please?
Mark
I'll get some pics/dimensions tomorrow
cheers
Pics, the rad is 70x32 at its widest points. it was 10cm too wide to go between the bonnet mounts on my fury. Measure twice buy once
Oil cooler
Ohh..too big for me sorry
I need the same? as the one in your archives. What size is that and have you had any problems running it upside down?
Mark
Hi,
Its not got any fluid in it yet, can't see any problems in using it upside down though to be honest, I've mounted it like that as its better
for coolant hose access. It makes no odds at all how you mount it.
This is the one I brought...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=310158712557&ssPageName=STRK:MEWNX:IT
Bargin and arrived within 48hours.
Franky,
Thanks, I intend to mount it the same way for the same reason. All my coolant pipes are on the off side of the car. Have you just blanked off the
bleed ?
Mark
as far as i'm aware there's only the inlet and outlet along with the fan switch hole. M22x1.5
